Lights still flicker and battery gauge still dances after cap install
Old Nov 2, 2002 | 10:07 PM
Z28STYLE23's Avatar
Well, it was worse before i got the cap in. But i have the system listed below in sig and added the 1.2 F cap and it controlled the battery level much better. But at night with the lights on and in drive while sitting at a red light playin music the battery level will get to alittle below half to the middle of half and the red. And the lights dim a bit when it hits. So what should i add, check, or what.
Old Nov 2, 2002 | 10:43 PM
LS1 RULZ's Avatar
Providing that your power and ground cables are of adequate size your next step is a high output alternator.
Old Nov 3, 2002 | 02:38 PM
Z28STYLE23's Avatar
What is the output of the stock alternator? And where would I be able to get a high output alternator? Jegs or Summit? I just don't see many guys goin this route but if i have to i have to.
Old Nov 3, 2002 | 03:30 PM
x7x7's Avatar
My stock alternator is 140A. I assume you have the same. Before you get a new alternator I would try upgrading the alternator and battery wiring to at least 4 gauge.
What gauge is your main power wire?
Old Nov 3, 2002 | 03:37 PM
LS1 RULZ's Avatar
I'm not sure what year they changed but newer F-bods only have 105 amp alts. But that's their max output. At idle speeds the output is considerably lower than that.
Old Nov 3, 2002 | 04:10 PM
x7x7's Avatar
I believe they changed to 105 in 98, that's what I've read.
Old Nov 3, 2002 | 08:04 PM
weaponZ's Avatar
here are the steps i took
1)cap
2)4-guage alt. wire
3)200amp alt.
4)red top batt.
problem solved
Old Nov 3, 2002 | 08:50 PM
firebirdude's Avatar
Mine is 105amp too. And the idle output is something to look for when buying a H/O alt. Sure... it'll do 200amps.... but only at 3k RPM's..... at idle, 10 amps...... been there, wasted money.
Mine is a 1996 V6 and it has 105amp stock.
E-mail Dominick for a H/O alt. He offers some high output at idle alts. for a VERY nice price. E-mail him at dominick@tds.net Tell him the navy dude sent ya... he'll know who I am. Yes... also, it would be a good move to upgrade the output wire from your stock alt. to 4g.
Old Nov 3, 2002 | 11:46 PM
x7x7's Avatar
V6 4th gens have always had a 105A alternator. It's the Z28s that changed to 105A in '98.
Old Nov 7, 2002 | 08:48 AM
BandDirector Blk98ZM6's Avatar
Just to double check, you are NOT running any fuses between the cap and the amp, are you? Fuses between the cap and amp decreases the effectiveness of the cap.
97z28k&N
Jan 9, 2015 04:58 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
ro2207
Dec 4, 2014 06:18 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
CLEAR
Aug 30, 2002 07:49 PM
