Kicker s12L7 Break in time....
Old Sep 10, 2002 | 12:59 PM
97FormulaWS-6's Avatar
Post Kicker s12L7 Break in time....
OK.. First off - Steve - great box, everything looks/sounds great.
Second...
I got everything hooked up last nite and am now starting the break-in process on my subs. They're each in a 1.5cf sealed box (Subthump). How much time should I allow before I really crank it up?? The paperwork says about 2 weeks, but I know it's supossed to be longer break-in in a sealed box.
Oh, and my system...
Alpine CDA-7894 HU
Alpine ERA-G320 EQ
MTX Crossover
Audiobahn A2200HCX (1600Wrms x 1 @ 1)
JBL 4Ch amp (Forgot model number)
Kicker s12L7 (2)
Infinity Kappa 652.1 (Front & Rear)
2x 1 Farad Caps
Mike
1997 Formula WS-6, 1 of 473
Mods: P&P MAF, Pro-5.0, SLP LT4 Clutch, 200 Amp Alt, TB Bypass, !AIR, !CAGS, 160 therm, CSI WP, PS Cooler, GMS STB, Cutout, Ferco/Debaffled Hood, TCI LineLock, ES Swaybar/Trans/TA Bushings, 5%R/20%S Tint, Painted Calipers, Custom Clear Tail Lights/Corners
http://camaroz28.cardomain.com/id/97formulaws6
Old Sep 10, 2002 | 02:54 PM
megabass's Avatar
Post
Thanks for the compliments on the box Mike. I've had my 10" solobarics back in the car for about a month and they're just now starting to sound good. From what I've seen the 10s have a tighter suspension though. But I'd say it will take longer than 2 weeks. If you have a local shop that can hook them up and break them in overnight, that might be worth looking into.
Steve
4th Gen F-Bod sub boxes
www.subthump.com
Old Sep 10, 2002 | 03:33 PM
x7x7's Avatar
Post
Depends how much you listen to them. With the last subs I bought (my current ones) it took about 2 weeks or approx. 15-20 hours of listening at high levels before they were broken in. For the system I installed in my cousin's car recently it took about 2 months for the sub to break in because he doesn't crank it very often.
Just to clear something up, you don't have to keep the volume down on a new sub and the fastest way to break it in is to listen to it loud. Think about it, if it's not moving very much how is it going to break in?
'96 Firebird Formula M6
Performance
Custom cut-out, Homemade 4" CAI with 9" cone filter, !CAGS, TB Bypass, Manual fan switch, Energy Suspension Trans. Mount, Taylor 8mm Wires, Pro 5.0 shifter, LCAs, Stock 3.42 gears
Stereo
Sony Xplod MP450X MP3 Headunit, Sony XE-90MKII Half DIN EQ, MTX RTX01A Crossover, 2 12" Clarions, powered by 2 Bridged Kenwood KAC-728S amps, Infinity Reference Series component set up front, powered by Kenwood KAC-628, EFX 1 farad cap
Pic
Old Sep 10, 2002 | 03:45 PM
Post
True, low levels won't make it break in any faster... but I don't want to just dump 800Wrms into the speaker, without it being broken in.. I've een listening to them at a decent level, but not loud enough to make myself go deaf....yet..
Mike
Old Sep 10, 2002 | 04:50 PM
megabass's Avatar
Post
But if you read Kicker's manual it says "moderate" levels until it's broke in. I would think that just cranking a brand new sub full wattage at loud volumes would be hard on it. Maybe even cause unwanted stress or even failure since you're forcing stiff components to move violently. I think I read that this is the biggest cause of failure--improper break-in. Just like when you get a new car. You're supposed to take it easy for awhile. JMO
[This message has been edited by megabass (edited September 10, 2002).]
Old Sep 11, 2002 | 11:57 AM
Polecat's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by megabass:
But if you read Kicker's manual it says "moderate" levels until it's broke in. </font>
correct.....
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
