Kicker 04KX1200
Old Sep 5, 2005 | 03:51 PM
HotNickeLz's Avatar
Kicker 04KX1200
I plan on purchasing the amplifier listed below. It states that it runs at 1200 watts at one ohm. Does that mean that it can only power a single woofer? If not, what sub type would be best for the amp (dual 2-ohm, or 4 ohm)?
http://www.woofersetc.com/index.cfm?...Product_ID=269
Old Sep 5, 2005 | 04:53 PM
chris96camaro's Avatar
Re: Kicker 04KX1200
You can run more than one sub off that amp...You will need to get either one dual 2-ohm sub, or 2 dual 4-ohm subs to be able to use all 1200 watts
Old Sep 5, 2005 | 05:47 PM
bt96ss's Avatar
Re: Kicker 04KX1200
Good amp most birth out near 1500 watts. They are very underrated. You will be pleased. I would go with 2 dual 4 ohm Kicker L7 12 inchers.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
kandied91z
Mar 3, 2015 11:34 AM
Snoman73
Nov 17, 2014 07:22 PM
'94 Bad A Z28
Nov 14, 2002 11:02 AM
LS1346CID
Aug 27, 2002 12:27 PM
