Key Fob
Key Fob
I'm not 100% sure where to post this but this says electronics so I figure I'm not far off? lol.
Anyways I decoded my RPO's and found that my car did come with factory keyless entry. I got a fob today from a friend that I believe should work but I cant figure out how to program it. Anyone know?
I found this on an S10 forum through google:
But it didnt work. Is there a different method?
Direct from GM's S/T 1998 Manual page 8-856
Transmitter Programming:
1)With the driver door closed, hold down the power unlock button on the door panel.
2)Turn the ignition switch to the ON position
3)Turn the ignition switch to the OFF position
4)Turn the ignition switch to the ON position
5)Turn the ignition switch to the OFF position
6)Release the power unlock button on the door panel.
The remote control door lock reciever will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1)Locking the doors
6.2)Unlocking the doors
IMPORTANT:
All extra transmitters must be programmed at this time. When a new transmitter is programmed it will deactivate the old transmitters.
7)Hold down the lock and unlock buttons on the transmitter until the remote control door lock reciever will respond in the following manner:
7.1)Locking the doors
7.2)Unlocking the doors
8)Repeat step 7 for each additional transmitter
9) Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
IMPORTANT:
I know this isnt the factory 3 button one but I looks like an aftermarket GM style. I guess it didnt work
Anyone ever seen that one?
Also, would a pontiac one work? I have a friend that offered to sell one of his but he's pretty sure it says pontiac on it lol.
68camaroboltz
Oct 5, 2015 11:56 PM
autoxr166
Sep 25, 2015 04:21 PM
