Inverted Sub.
Old Aug 1, 2003 | 12:46 PM
RCJim's Avatar
Inverted Sub.
What purpouse does mounting your subwoofer in the box inverted (upside down) serve?
My new HU has an option on the organic EL which allows you to tell it which way your sub is mounted in the box. I thought I might try flipping it depending on what it would do. It hits DAMN hard right now.
Old Aug 1, 2003 | 01:03 PM
FyreLance's Avatar
For looks. Or to save space (since you won't have the space your sub takes up subtracted from the volume of the box). Doesn't matter too much which way it's mounted.
Old Aug 1, 2003 | 01:23 PM
got_hp?'s Avatar
fyre is right................it doesnt change anything...........its just for looks
however.........sometimes a sub creates annoying noises when inverse mounted............leadwires tapping cone, or wind noise from the magnet vents
usually not loud enough to hear though.
Old Aug 1, 2003 | 01:32 PM
x7x7's Avatar
Fyre is correct. Most good quality drivers can be inverted, it depends on the suspension stiffness. Take a look at this: http://www.adireaudio.com/tech_paper...rientation.htm
Old Aug 1, 2003 | 02:46 PM
RCJim's Avatar
Thanks for the inpuit guys, I had always wanted to know what the signifigance of it was.
Pampered-Z
Apr 14, 2015 05:38 PM
CARiD
Jan 27, 2015 06:27 AM
chifrankbpp
Jul 20, 2003 02:14 AM
twells
Mar 21, 2003 02:06 AM
PaulN64
Aug 7, 2002 06:17 PM
