Installing stock 95 Z28 CD H/U in 95 Beretta
Old Aug 10, 2003 | 11:20 AM
n2oCamaro's Avatar
I have removed the stock H/U from my Z28 to make room for gauges and I want to put it in my Beretta since it does not have a CD H/U. I do not want to cut the harness in the Z incase I want to put it back later. The harness in the Beretta is very similar exept for one block. Does anyone know a way to get this wired up correctly. Thanks for any suggestions.
Old Aug 10, 2003 | 11:01 PM
NineSevenWS6's Avatar
It will be fine.
Old Aug 11, 2003 | 08:26 AM
n2oCamaro's Avatar
Originally posted by NineSevenWS6
It will be fine.
What will be fine?
Old Aug 11, 2003 | 11:31 AM
Assuming you can fit the thing in there, the harness in the beretta will work fine.
Old Aug 11, 2003 | 02:48 PM
megabass's Avatar
Re: Installing stock 95 Z28 CD H/U in 95 Beretta
I thought Beretta's came out in '87 or '88. I had an 88. Anyhow, I have the aftermarket trim piece for that car. Came from crutchfield and extends down and includes the A/C control trim.
Old Aug 11, 2003 | 10:12 PM
he has a 95...
Old Aug 13, 2003 | 09:30 PM
n2oCamaro's Avatar
I can get it to fit with no problem. I had tried hooking it up before, but one of the blocks of the Beretta harness is different. It has slots for 7 pins (this block on the Camaro H/U has 6 pins) Any ideas?
Old Aug 14, 2003 | 12:18 PM
it is the same harness (aside from the other block, but it shouldnt matter), it should plug right in....
Old Aug 14, 2003 | 09:07 PM
n2oCamaro's Avatar
Nope! That block on the Z H/U is only 6 pins wide. That block on the Betetta harness is 7 pins wide so it will not go in. (Too wide) There is another seperate block on the lower half of the Z H/U that is a 7 pin connector but has 6 pins (One pin slot is empty) I tried plugging in there but it didn't work. I can get sound but it is about half the volume it should be. Maybe I should just try to find a Camaro harness seperatly and run the wire.
Old Aug 14, 2003 | 11:23 PM
was it a bose radio?
Old Aug 15, 2003 | 06:41 AM
n2oCamaro's Avatar
The Beratta's H/U is not Bose. Delco I think.
Old Aug 15, 2003 | 10:19 PM
is the CD player youre putting in there a bose?
does the plug not fit? or are there just extra wires?
Old Aug 15, 2003 | 10:32 PM
n2oCamaro's Avatar
Yes, Bose CD.
The plug does not fit for the upper right block.
thenewkid
Nov 27, 2014 09:41 AM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
