installing foglights
Old May 10, 2004 | 01:00 AM
GoFast908Z's Avatar
Member
my left foglight just went out, and I have a new bulb. How the heck do I change it?
Old May 10, 2004 | 01:22 AM
nothingeined's Avatar
You got two options. You can go through the bottom or just squeeze your hand from on top. I usually remove my headlight housing. Makes it a lot easier.
Old May 10, 2004 | 01:38 AM
ReNxWar's Avatar
http://www.bfranker.badz28.com/fbody/GuidesTop.htm Theres a foglight tutorial on there. I just take off the housing and change the blub and put it back. Be careful with those pins, they want to make their new home inside the bumper .
Old May 10, 2004 | 03:46 AM
GoFast908Z's Avatar
Member
tutorial is for 93-97. I have a 98.
how do you get to it from the bottom, and if you remove the headlight, how do you make sure it's lined up straight when you put it back in? Also, are there any special tools needed?
Old May 10, 2004 | 10:29 AM
I never really did it from the bottom. Everybody told me too so I tried and no luck. There should be like four or five bolts holding a black panel on the bottom. Just unscrew them and you have access to them. I did that and for some reason my panel did not want to come off. So I just undid the one 10mm screw that holds the headlight in and wrestled with it for a bit and it came off. Complete access to the foglight and corner bulbs too. Swiched it then just wrestled the headlight back on and was done with it. They are still aligned since they can only sit back in a certain way. When you open your hood, you will see what I mean. The headlight has two tabs that you need to slide in order to get the housing out. I know it sounds like a lot, but it's not.
Old May 10, 2004 | 11:25 AM
ReNxWar's Avatar
Sorry about that, I didn't realize you had a 98.
Old May 10, 2004 | 11:46 PM
GoFast908Z's Avatar
Member
its ok. thanks guys.
Nov 18, 2023 07:21 PM
PROJECT X
Apr 17, 2015 12:13 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
TheV6Bird
10
Aug 2, 2002 08:00 PM
