I want a system that will pound
From experience - tell me what will pound in my car as far as 2 12" subs and what amp to use. Give me some brands and model numbers if possible.
To date i've had:
Audiobahn 1251 subs
Crunch fatboy subs
American Pro subs
each setup with a Lanzar Vibe 800 watt amp.
I need a new setup, please help.
Thanks,
Troy.
AIM: pimpintroy
To date i've had:
Audiobahn 1251 subs
Crunch fatboy subs
American Pro subs
Thanks,
Troy.
AIM: pimpintroy
2 Adire Audio Shiva's $125 each www.adireaudio.com
1 JBL BP600.1 about $200 www.ikesound.com
throw away whatever box you have and get a new one from www.subthump.com
Depends on what model of Rockfords you're comparing them to. For the money, I would take a pair of shivas over most or maybe all Rockford subs. The thing about shivas is that they need a larger box. If you give them 1.5 cubes each, look out. Rockfords can play in a slightly smaller box.
The Brahmas as I mentioned before are in a league of their own. Right up there with the W7.
Sweet. Now would an 800 watt or 1000 watt lanzar vibe amp push 2 of those?
And megabass - I've talked to you about getting a box from you - unfortunately the insurance isn't paying
but i'm working on the funds for it - would your box be big enough for these subs?
Thanks for your help!
but i'm working on the funds for it - would your box be big enough for these subs?Thanks for your help!
800 watts will be plenty I'd say. They'd hammer for sure. I've got a customer hitting 147 dbs with 750 watts, my box and two alpine 12s. Another thing you could look into is getting a pair of used JL12Ws. Those are still nice, then you could upgrade as you get the funds. I happen to know someone in anderson who may have a pair for sale. If you want, I can check.
Can you find out if your friend in Anderson has the JL12W's for sale, which one's they are, and how much he wants for them?
I'm liking the new t-top box man - think I might go with that.
Do the t-tops just lay down into the hole then?
I'd get W3s IMO. W6s were meant to be used in 3s. I believe they are 6ohm subs. The W3s will be easier to wire and get the impedence you want.
But Shivas vs 12W3s..Shivas are a tad better and maybe less expensive. But you will need my larger deeper box for them. If you get the JLs then you can get by with my standard box.
