How to splice?
Old Apr 26, 2004 | 10:24 PM
nothingeined's Avatar
How to splice?
I got some Halo headlights and I want to hook up the LED in the middle up. It says I need to splice into my parking lamps or foglights. Does that mean to take the actual wires, cut them in half, then tie these in back together with it and tape up it? Or am I thinking about it wrong. The ends of the wires are just tips stripped off. If anybody can help, thanks! I have pics of the wires and lamps.
Old Apr 26, 2004 | 11:59 PM
Tair's Avatar
For this application T-taps would work fine. Go to any local hardware store and they should have them. This works fine for any low-current devices, such as the LED's. If you want the BEST connection possible, buy an automatic wire stripper. One grip of the wire stripper and it'll split open the wire, so you can solder the additional connections. Solder is always the best way to go when you are dealing with high-current devices.
Old Apr 29, 2004 | 02:22 PM
lantern's97Z's Avatar
What about trying those 3m connectors. Basically put the parking wire one on side and the led wire on the other clamp down with needle nose pliers and you done. very strong connection and no messy soldering
Old Apr 29, 2004 | 03:35 PM
Rashiki's Avatar
Those things suck.. t-taps would be much better. Be sure to get the right size tap.
Old Apr 29, 2004 | 06:02 PM
I ended up getting some t-taps. Made things a lot easier. I definately recommend them if someone does an install like that. Thanks!
Fastbird93
May 22, 2015 08:28 PM
onoiocoko
May 11, 2003 10:53 PM
OffspringZ28
Mar 4, 2003 01:23 PM
RED95LT1Z28
Feb 21, 2003 12:53 PM
Gripenfelter
Jan 7, 2003 03:20 PM
