How should i setup this sub and amp
Old Dec 14, 2005 | 07:42 PM
93transam1234's Avatar
here is the amp
http://www.dealclick.co.uk/product/6...OOD-KAC929.php
and the sub 10w3 d4
http://mobile.jlaudio.com/products_s...p?series_id=11
I dont know if i should have it wired parallel or series
My head unit lets me filter lpf and hpf (think thats`what it says) can set each of them to 0 75 or 125 not sure what to do here either
Im looking for a hardhitting sound
Old Dec 15, 2005 | 07:47 AM
LS1 RULZ's Avatar
Re: How should i setup this sub and amp
I would be hesitant about buying the Kenwood amp. I think that Kenwood makes some very good HU's but I feel that their amps are lacking. Whatever you do don't go by their "MAX" power specs. They are totally useless. Always go by the RMS power rating. If you insist on using that amp you would want the sub with dual 4ohm voice coils wired in parallel. This will give you a 2ohm load for the amp to drive. If you go with a different amp make sure that it can handle a 2ohm load.
Old Dec 16, 2005 | 07:11 AM
ice992's Avatar
As LS1 said, I wouldn't go with a kenwood amp... At the Audio shop I work at, we tested a few different Kenwood amps and that amp and the one right below it, put out MAYBE 105w CLEAN... after that, sure it might bump out 500w, but its not clean power at all. You'd never hear it until you got really loud but the little bit of distortion will over time damage your sub. If you are going to run one sub, go with the JL amp too... beleive me its worth the money you'll be much happier, the JL 250/1 monoblock amp is perfectly matched for that sub, and for 2 of them run the 500/1...
Just my $.02
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
