How many speakers do I have? 95 Z28
Old Dec 26, 2004 | 07:19 PM
RedRocketZ28's Avatar
I have the Bose system and have heard that I either 3 or 5 speakers. Which one is it? I have grilles for the back two speakers but it doesnt sound like there is anything coming out. I heard that there are two in the front and then the one sub thing in the trunk. So which is it? Thanks guys.
Old Dec 26, 2004 | 08:20 PM
Keepinitreal's Avatar
Re: How many speakers do I have? 95 Z28
I havent checked in a 95' but I had a 94' and I had 5 speaker system. Bose system. Had 2 in front (6.5''), 2 in back seats (6.5'') and one in the back left side which was 6.5'' sub (or misbass) that was connected to a port hole enclosure. If you change anything on the system you need to change everything. The grill covers pop off very easily. Just slowly figure out where the clips are connected behind the cover and gently pry open the covers. Should only take 2 minutes even if you dont know what you are doing. I can have then off in 15 seconds. So just take your time and find out. If you plan on changing your system then I always have ideas. It is very easy to run wire from an amp to those rear seat enclosures and run 6.5'' midbass kicker comps in there. PEACE! K.I.R
CamaroHeed
Mar 18, 2020 09:50 PM
Rod Bender
Jan 1, 2015 03:18 PM
MJ_Z28
Aug 8, 2002 09:07 PM
Thebeast431
Aug 8, 2002 01:39 PM
30thZ286speed
Aug 3, 2002 04:54 AM
