How to increase the range of a pager alarm?
Old Aug 22, 2003 | 08:49 PM
Gripenfelter's Avatar
I have a DEI 795W
I was brainstorming with a friend about possible ways of extending the range.
So far we came up with:
Soldering a flexible wire antenna to the pager unit that u carry.
Gluing a ribbon type antenna to the entire perimeter of the rear hatch window.
Anyone have any experience with this or know if this would increase the range?
Old Aug 26, 2003 | 09:15 PM
slayer6x6's Avatar
hold the key pad up to your chin
Old Aug 30, 2003 | 12:04 PM
kingman109's Avatar
sadly the chin thing really does work...and i must say i have tried it
Old Sep 7, 2003 | 02:24 AM
WS6Formula's Avatar
Increasing the size of the antenna shouldn't do anything but hurt it if it's already sized properly. The Antenna should be 1/2 the length of the radio wave it's trying to put transmit or recieve. If you look around online you can probably find what frequency your pager system works on & then find the formula. it's a really simple formula but I can't remember it at the moment
Old Sep 7, 2003 | 09:09 AM
LS1 RULZ's Avatar
wavelength in meters = 300 / frequency in MHz
Example: f = 9.68 MHz
wavelength = 300 / 9.68 = 30.99 meters
1 meter = 3.28 feet
According to this formula, a frequency of 9.68 MHz would be equivalent to a wavelength of 30.99 meters, which we would round to 31 meters.
As the formula indicates, the wavelength of a radio signal decreases as its frequency increases. This is important because the length or height of various types of antennas must often be a fraction (usually one-quarter or one-half) of the wavelength of the signal to be transmitted or received. This means that most antennas designed for frequencies near 4000 kHz will be physically much larger than antennas designed for frequencies near 30 MHz.
You can read more here.
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
NewsBot
Sep 14, 2015 02:02 AM
