How to determine which gauge power cables to use for amp?
Old Jul 9, 2003 | 05:52 PM
$hawn's Avatar
How would you determine which gauge power and ground wires to use for the amp, when I bought the car it already had 10gauge in it, the amp is an MTX TH2150XRMS at 2 ohms is 150x2. I think the length is important too aint it the longer the thicker it needs to be? I'll be running it in the back if it matters. Would I be better off goin to some 8 gauge? Thanks for any input.
Old Jul 9, 2003 | 06:38 PM
LS1 RULZ's Avatar
Wire Guage Chart
Old Jul 13, 2003 | 03:39 PM
$hawn's Avatar
The total draw is about 43amps, and i'll need about 15-16ft. More importantly will I notice a difference with 8guage over 10, if the amp seems to be getting enough power, it's pretty bassie as it is, will it be even more bassie, or will it improve the overall sound w/8g? Thanks for the help.
Old Jul 13, 2003 | 04:17 PM
slayer6x6's Avatar
The bigger the better
The same thing goes for speaker wire. I had my whole system wired with regular 18 ga speaker wire, then I rewired everything with 12 ga competion speaker wire and it sounded like a completly different system. You can have the best amp in the world and with out the right wires, it wont work to its full potential. Its like trying to put out a forrest fire with a garden hose
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
97z28k&N
Jan 9, 2015 04:58 AM
sleeperZ96BT
Jul 24, 2002 11:28 AM
