Horn/Relay Issues?
Old Dec 21, 2010 | 11:16 PM
SPM81392's Avatar
Horn/Relay Issues?
Hey guys, I hope this post is the right place, First time poster (Sorry). Anyways i woke up at 4:45 AM last night to my horn going off and i was not able to shut it off. So i disconnected the battery and started looking around at other posts one mentioned pulling fuses, which i tried with no luck. Every time i tried to reconnect the battery the horn would just turn back on. Im thinking maybe relay issues? I have a 96 RS V6 and owned it now for over 6 months and this has never been an issue. When i took it no my mechanic for a tune up right after i bought it he told me the horn was disconnected and reconnected it for me. Is there anyother fuses i can try? Can i pull the relay? Or can i pull some wires under the hood to disconnect it? Any advice would be appriciated.
Old Feb 11, 2011 | 03:59 AM
L.dookie's Avatar
Re: Horn/Relay Issues?
Most likely it will wind up being one of the switches stuck, but if you take the panel under the front right of the bumper off there is a plug and you can just unplug the horn. to check if one of the switches is stuck or something like that you should be able to find a plug somewhere near the steering column. unplug it. if the horn stops you'll probably have a stuck switch. I cannot however remember if there is a relay.
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
