Home Theater Sub in Camaro
Old Jan 15, 2004 | 08:38 PM
93Cam's Avatar
Well i had a system all picked out but turns out shipping was gonna be $80. So plan B. Will a sub that is from a home shelf stereo work in my car.
Old Jan 16, 2004 | 05:32 AM
LS1 RULZ's Avatar
If you can get the proper sized box for the sub in your car it will work fine.
Old Jan 16, 2004 | 01:13 PM
93Cam's Avatar
Thanks. I just wanted to make sure the whole ac vs. dc didnt mess up the sub.
Old Jan 16, 2004 | 01:19 PM
LS1 RULZ's Avatar
I don't follow you. Subs (home or car) don't run on DC voltage.
Old Jan 16, 2004 | 08:24 PM
93Cam's Avatar
Theres ac in the house and dc in the car right? Thats what i ment. But i understand that i can use it. Thanks
Old Jan 16, 2004 | 08:55 PM
megabass's Avatar
What he's saying is that your sub is powered by wattage not voltage. Watts are produced by the amplifier. A home stereo amp uses a/c to produce watts, whereas a car amp uses dc to produce watts. So in your sub's case, ac vs. dc has no bearing
Old Jan 16, 2004 | 08:58 PM
LanceJoker's Avatar
Umm.....forgive me if I am wrong here for I will sound pretty stupid,but most home speakers are 8 Ohms where as most car speakers are either wired at 2 or 4 ohms depending on the application.Not sure how the home sub would work.I've seen it done before but they always end up blowing before to long.
Old Jan 16, 2004 | 09:06 PM
megabass's Avatar
That's true. It probably is an 8 ohm sub, but it will still work. Not ideal, but will work. Add another 8 ohm sub and that'll knock it down to 4 ohms.
Old Jan 16, 2004 | 10:19 PM
LanceJoker's Avatar
Thanks Steve,I wasn't exactly sure how that would work.Didn't even think of adding a second sub to knock it down to 4 ohms
Old Jan 17, 2004 | 04:54 PM
93Cam's Avatar
Ya LanceJoker you are correct. The sub is 8ohms. Running two of them together to make 4ohms is outa the question, cause the sub is 15". I'll just have to wire it so its running on 8ohms. Thanks guys.
Collector Car
Jan 5, 2015 10:58 AM
bernie1951
Dec 10, 2014 10:03 AM
dreamer1q
Jul 24, 2002 04:39 PM
dreamer1q
Jul 9, 2002 05:37 PM
dreamer1q
Jul 8, 2002 08:47 PM
