Hi-Beams and Lo-beams at the same time??
Old 05-09-2007, 12:22 AM
SVThuh's Avatar
Is there any way to wire this up? I just installed an HID kit on my 01 SS and I want the low beams to stay on when I hit the high beams. Is there any kit or diagram anyone has to make this possible?
I just dont want to give up the extra light from the HID's when Im in the twisties at night and I dont want to keep shocking the HID bulbs everytime I toggle the Hi-beams
Thanks for the help everyone!
SVThuh is offline
Old 05-09-2007, 07:19 PM
bmnicolosi's Avatar
you could use a relay.
85 - ground
86- high beam trigger
87- 12 volt
87a- switch side of low beam
30- headlight side of low beam
if the high beam trigger is negative, change 85 to 12 volt source.
if low beam is negative trigger, change 87 to ground.
bmnicolosi is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
Feffman
10-09-2015 05:42 AM
ChrisFrez
02-01-2015 08:26 AM
capebuf
01-13-2015 07:22 PM
Quick Reply: Hi-Beams and Lo-beams at the same time??
