Hi-Beams and Lo-beams at the same time??
Is there any way to wire this up? I just installed an HID kit on my 01 SS and I want the low beams to stay on when I hit the high beams. Is there any kit or diagram anyone has to make this possible?
I just dont want to give up the extra light from the HID's when Im in the twisties at night and I dont want to keep shocking the HID bulbs everytime I toggle the Hi-beams Thanks for the help everyone! |
you could use a relay.
85 - ground 86- high beam trigger 87- 12 volt 87a- switch side of low beam 30- headlight side of low beam if the high beam trigger is negative, change 85 to 12 volt source. if low beam is negative trigger, change 87 to ground. |
