Hi-Beams and Lo-beams at the same time??
Is there any way to wire this up? I just installed an HID kit on my 01 SS and I want the low beams to stay on when I hit the high beams. Is there any kit or diagram anyone has to make this possible?
I just dont want to give up the extra light from the HID's when Im in the twisties at night and I dont want to keep shocking the HID bulbs everytime I toggle the Hi-beams
Thanks for the help everyone!
you could use a relay.
85 - ground
86- high beam trigger
87- 12 volt
87a- switch side of low beam
30- headlight side of low beam
if the high beam trigger is negative, change 85 to 12 volt source.
if low beam is negative trigger, change 87 to ground.
85 - ground
87- 12 volt
ChrisFrez
Feb 1, 2015 08:26 AM
