HELP upgrade stock system.
Old Jul 8, 2003 | 11:57 AM
SATANAZ666's Avatar
HELLO,
I need some help guys. I have a 1994 Trans am, and it only has a stock 4 speaker system. Right now I only have enough loot to change the speakers. Can someone explain to me the difference in 2 ohms and 4 ohms?. I know I have 2 ohms.....how i do i make this bad boy 4 ohms?????? will changing the speakers alone do it? and what speakers are good and a little economical. Im on a budget..please help. My stock system sucks!..HAHA
Thanks In advance.
Old Jul 8, 2003 | 05:15 PM
BandDirector Blk98ZM6's Avatar
Ohms is a measure of resistance. If you have a 2 ohm system and try to use 4 ohm speakers, the 4 ohm speakers have more resistance, so they won't be as loud. However, if you have a 4 ohm system and replace the speakers with 2 ohm versions, it will be louder, but it could damage the amp if the amp isn't 2 ohm stable. If the amp isn't 2 ohm stable and you use 2 ohm speakers, the amp will overheat and shutdown and/or become damaged.
Old Jul 16, 2003 | 11:41 AM
SATANAZ666's Avatar
ok anyone else......
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Aneurysm
Sep 9, 2002 08:09 AM
