Help!!! Aftermarket radio not turning on
Old Jul 2, 2011 | 11:19 PM
96camaroz281988's Avatar
I have a 96 camaro z28 and it had the Bose system it. I just put an aftermarket head unit in and it was working just fine until I realized I mixed up the speak wires so I went back to fix them and hook them up to the right ones then I turned the car on to acc to see if it was working and now the car dings 2 times and the seat belt light flashes when I put it in acc and now the radio won't turn on. **
Old Jul 7, 2011 | 12:20 PM
bobbyk3lly's Avatar
Re: Help!!! Aftermarket radio not turning on
sounds like you might have mixed up some wires again. if you can say wire up the old stoc harness back into the car and buy the dash kit for $9 at walmart.... if you dont have your stock wiring connector anymore i have one from a bose car ill sell you
Old Jul 14, 2011 | 08:33 AM
eanhl2004's Avatar
you could try checking the wiring according to the typical color section here
http://www.installdr.com/InstallDocs/GM/PDF/460061.PDF
I installed my stereo using crutchfield instructions and had one minor issue I think but don't remember what it was...maybe two wires were colored as what they stated maybe you moved a power wire or ground?
Old Jul 14, 2011 | 11:55 AM
Kendell347's Avatar
Any luck? were all the wires plugged in? Is the radio doing anything? Have you checked your fuses?
Old Jul 15, 2011 | 12:15 AM
eanhl2004's Avatar
Check fuses first, you could have crossed some wires and blew a fuse! And if you did blow a fuse you may need to recheck your wiring... heat shrink is better than electrical tape
Old Jul 23, 2011 | 08:51 PM
sorry it took me so long to reply. its not the radio or my wiring becuase i triple checked everything and also it wasnt just the radio not working i could even roll the wondows up too so i check everthing that could have went wrong and i didnt find anything incorrect so by the time i did all that it was dark so i called it a night and i went back in side and then 2 hours later i went back out to try it so i could roll my windows up everything worked. so idk what it could be.
Old Jul 25, 2011 | 09:07 PM
calaban's Avatar
Maybe a problem with the BCM.
Old Jul 27, 2011 | 02:00 AM
bobbyk3lly's Avatar
sounds like a vatts problem... my car did the same thing...
warmeck
Mar 22, 2015 10:28 AM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
