Garmin GPS Hardwire
Old Sep 8, 2008 | 05:52 PM
CL21376's Avatar
Garmin GPS Hardwire
Anybody know how I would go about hard wiring a GPS (specifically a Garmin Nuvi 260) into a 94 F-Body?
I only have one 12V power outlet, and thats kinda reserved for my radar detector. I know I could get the double cigarette lighter, but those are so bulky....
Ideally, I'd like to put it near the drivers side A pillar. Any ideas or suggestions?
Sorry if this has been asked before....I searched around and didn't find anything on this.
Thanks!
CL
Old Sep 8, 2008 | 07:14 PM
Green96Z's Avatar
I believe the wiring harness for the rear view mirror lights runs under the driver side A-pillar. You can splice into that. It's 12v hot at all times, so you need to make sure you can turn off the GPS. That's what I spliced into for my radar detector.
Old Sep 8, 2008 | 08:29 PM
CL21376's Avatar
might it be easier to do something like this:
http://www.radioshack.com/product/in...entPage=search
and hide it up under the dash? seems simple enough....positive and ground!?!
Old Sep 9, 2008 | 06:05 PM
Green96Z's Avatar
Sure you could do that, but hard wiring it is the easiest way to hide it. I mounted my radar detector up above my rear view mirror, and didn't want the adapter hanging down, so I hardwired it into my mirror wires. You can wire it to any 12v source and a ground.
Old Sep 11, 2008 | 01:31 AM
burnout96's Avatar
you can hardwire it yourself very easily. Take the Cig lighter power cord from the gps. Unscrew the top and attach a piece of wire to the nipple on the end of the cig lighter. The outer metal pieces on the end of the cid lighter are your ground. hook a piece of wire up to one of them and tape off MAKE SURE THE NIPPLE AND THE GROUNDS ARE NOT TOUCHING... find a 12v SWITCHED power source and a good ground. hide wires and your done
any ?'s just PM me
1FASASZ
Feb 28, 2004 04:04 PM
Newbie97
Jan 12, 2004 10:21 AM
Jeff H
Middle Atlantic
Feb 4, 2003 10:48 AM
SuprChrgdFBody
V6 Tech
Sep 12, 2002 11:29 PM
