Flush mount Head Unit
Old May 26, 2003 | 11:07 PM
z28jaz's Avatar
Has anyone ever flush mounted their headunit so it is even with the dash? I really hate how it sticks out now, not to mention it occasionally gets in the way when I shift.
Any information or install guides would be appreciated.
Old May 27, 2003 | 02:37 AM
95 3.8's Avatar
mine didn't stick out.
Old May 27, 2003 | 02:59 AM
PredatorZ28's Avatar
mines flush..dunno? pictures in sig i think
Old May 27, 2003 | 06:18 AM
Indelibility's Avatar
Just make a new face plate. I just made a new one last night out of plexiglass, I'm going to finish it up with paint and some vents. I raised the hole up so it clears that little plastic tab in the dash. It's not hard to make one.
Old May 27, 2003 | 12:56 PM
x7x7's Avatar
Metra makes a flush mount kit....
Old May 27, 2003 | 02:02 PM
97FormulaWS-6's Avatar
I made my own flush kit with a piece of 1/8" 6061 Aluminum. Cut it all out, sanded it, and polished it up. It turned out pretty darn good for a first shot.
Old May 27, 2003 | 02:34 PM
firebirdude's Avatar
Yes they do!
Copied from ls1.com FAQ thread:
The following are Metra install kits:
40-GM10 - Gm factory antenna to aftermarket head unit
99-4544 - '82 and UP GM multi-kit with 1/2 DIN EQ option
99-3300 - Chevy/Olds/Pontiac 1994 and UP dash kit (flush)
99-3009 - Camaro/Firebird 1993 and UP dash kit (flush)
Best Kits is a Metra alternative (little better quality too):
BAA4 - GM Antenna adapter
BHA1858 - 1997-2001 Wiring Harness
BKGMK432, - 1997-2001 generic dash kits for F-body
BKGM4
BKGM8 - 1997-2001 Camaro specific kit
BKGM9 - 1993-2001 Firebird specific kit
BKSAC656 - 1993-2001 Firebird speaker adapter
Best Kits also has link for adding CD changers, etc.
Old May 27, 2003 | 03:29 PM
z28jaz's Avatar
Thanks Guys,
That's some great info. I think I'm gonna do this next week.
Old May 27, 2003 | 04:43 PM
They make flush kits, but depending on how deep your reciever is, you may end up using the 1/2 inch attachment. In the opening, there is a plastic tab that blocks the HU from reaching all the way in. IF that's the case, a new one is not hard to make. I'm just having trouble making mine connect . Hopefully some hot glue will do the trick
Old May 27, 2003 | 05:38 PM
x7x7's Avatar
Cut the tab off....
Old May 28, 2003 | 06:13 AM
Cut the tab off....
It won't interfere with anything? If that's the case than I'm putting the kit back on.
Dang, just when I got the custom faceplate on
Old May 29, 2003 | 02:05 PM
slayer6x6's Avatar
i just flush mounted my headunit in my 88 camaro. i used a ford K630 (i think??) kit. i broke off all of the mounting tabs and used the gm brackets and drilled holes in the ford kit and mounted the gm brackets on that kit. i dont know about the 4th gens but in my car you cant flush mount it unless you cut out the heating vents that come out of the side of the console because there wont be enough room to fit the head unit, thats why they make that ugly kit that sticks out an inch.
Old May 30, 2003 | 06:16 AM
I broke the tab off yesterday, and put in the flat dash plate. Now my radio looks great, no ugly protrusions.
By the way, I got a Pioneer DEH-P7400MP
Old May 30, 2003 | 01:28 PM
slayer6x6's Avatar
thats a nice unit man
Old May 30, 2003 | 03:08 PM
Hey thanks.
By the way, I used the Metra Dash Kit, pulling the tab down is real easy, if anyone wants instructions, PM me.
Alpine Type-R components and an Alpine amp are coming within the month.
Rod Bender
Jan 1, 2015 03:18 PM
Brian Demeter
Aug 21, 2002 02:07 PM
bman555
Aug 11, 2002 10:56 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
Absolute Z28
Jul 19, 2002 02:21 PM
