factory amp location
Old Oct 29, 2002 | 08:32 PM
vinnyxgunz's Avatar
where is the factory amp??? i cant seem to find it
Old Oct 29, 2002 | 08:34 PM
LS1 RULZ's Avatar
It's on top of the wheel well on the passenger side in front of the spare. It's mounted on a platic plate and is on the fender side of the plate. If you use the search function you would have found this info easily. This question gets asked often.
Old Oct 30, 2002 | 07:42 AM
1sloLS1's Avatar
do all the ls1 camaros have a amp there or is it just with the monsoon system?
Old Oct 30, 2002 | 07:49 AM
LS1 RULZ's Avatar
Just the POS Monsoon.
Most, if not all, BOSE systems have individual amp modules with each speaker.
Old Oct 30, 2002 | 08:58 AM
vinnyxgunz's Avatar
i meant the bose... not the monsoon... does it make a difference?
Old Oct 30, 2002 | 11:20 AM
LS1 RULZ's Avatar
Yes, it makes a difference. The POS Monsoon uses a multi-channel amplifier while the BOSE uses individual amplifier modules on each speaker.
Old Oct 30, 2002 | 03:23 PM
vinnyxgunz's Avatar
i took out all my speakers and replaced then with pioneer 3 ways... so does that mean they are all un-amped?
Old Oct 30, 2002 | 04:34 PM
LS1 RULZ's Avatar
That depends. What did you attach them to?
I haven't actually seen a BOSE setup in a Camaro yet so I may be mistaken. I'm going by what I HAVE seen in Corvettes and other BOSE equipped cars. In all of them each speaker had it's own amplifier module. Unlike the POS Monsoon system which uses a mult-channel amp. I should have made that clear earlier.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
30thZ286speed
Aug 3, 2002 04:54 AM
97QuasarBlue3.8
Jul 22, 2002 09:09 AM
