Electrical problem....need help
Old Oct 19, 2004 | 06:37 AM
v7guy's Avatar
For some reason my insturment cluster is pulling power from the power wire to my brakes when the brakes are hit.....as in, you hit the brakes and the insturment cluster lights up dimly and the passenger side brake light goes dim. My Brake! light is on. The 3rd brake light is not working, but I am not getting an ABS inop light either. Power is leaving the brake light switch for the third brake light and for the rear tails as it should.
Any help you guys can give would be appreciated.
Old Oct 19, 2004 | 08:13 AM
iamsickofitall's Avatar
Re: Electrical problem....need help
i had a problem like this in my nissan...turned out it was a bad bulb causing a short...i don't understand why the brake! light would be on if this is caused by the same type of thing tho
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
