dyno matt
Old May 10, 2010 | 02:00 PM
Drew24's Avatar
dynamat
Anyone know where I can get some and how much it would cost to cover the TA
Old May 10, 2010 | 02:29 PM
97FormulaWS-6's Avatar
it's dynamat not Dyno Matt.
http://www.fatmat.com/ is a reputable place to get it from.
Cost all depends on how much you want to do/cover.
Personally... I used a generic version (not name brand) and it sucked; I ended up removing it all. I then used foam weatherstripping between all the panels to eliminate the rattles; and 3M Ruberized undercoating to coat everything. Worked awesome. It requires a LOT more prep work as you MUST mask everything off that you don't want coated.
Old May 24, 2010 | 10:28 PM
merim123's Avatar
which foam weatherstripping? frost king?
Old May 24, 2010 | 11:46 PM
bluz28's Avatar
For sound deadening I'd look at RAAMmat or if you budget permits Second Skin.
80 sq.ft. and up will either be enough, or finish a large portion of it
PM sent.
Old May 25, 2010 | 08:12 AM
Yup, just the stuff you get at Lowes/Home Depot. Works the best for eliminating panel to panel rattles which is where 80% of the annoying sounds come from.
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
