Door panels?
Old Jul 4, 2003 | 04:50 PM
pimpedoutracer's Avatar
Door panels?
How do u take the door panels of, so i can hook a amp up to the speakers.
what tools will i need.
thanks..
Old Jul 4, 2003 | 07:00 PM
firebirdude's Avatar
First, do you have manual or power windows? If power:
1. Remove the 1 screw holding the plastic triangle piece by the side mirror. That piece will just pop off.
2. Pop off the door lock indicator. Can be a little tricky but it just pops off.
3. Remove the 3 big screws. 2 are in the arm rest area. The 3rd is under the handle you grab to close the door. It is kind of angled upwards. I believe the firebirds may also have a 4th big screw at the bottom of the door panel near the map holder area.
4. Remove the black plastic trim that goes around the handle and holds the switches. To do this remove the screw behind the handle and the screw angled upward near where the 3rd big screw was in step 3. Pop the piece loose enough to reach behind it and unplug the wiring harnesses. Some people like to pop out the smaller plastic piece that holds the switches first but I like to leave it in as the clips tend not to go back on as tight. Once the harnesses are unplugged you can remove the piece by twisting it to clear the door handle.
5. Now the door panel is ready to come off. It lifts up and out...not straight out. It has "j" hooks molded as part of the door panel and if you try to pull the door panel straight out you'll break the hooks making it impossible to keep the panel secure. It may be a little tight to move it up at first. I prefer to grab the panel near the weathestripping at the top of the door and pull it up and out just enough to unhook it from the top part of the door frame. This then gives you a good place to pull the rest of the panel up.
6. Installation is the opposite.
Old Jul 4, 2003 | 08:25 PM
thanks alot, will that still work the same way if i dont have AT windows.
Old Jul 4, 2003 | 10:28 PM
PaulN64's Avatar
since you have manual windows, look behind the crank and you'll see a 'C' clip there. Take that off but be sure you don't loose it. After that you'll be able to take the window crank off
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
z28cam1993
Sep 9, 2015 04:08 AM
blaze309
Sep 8, 2015 05:27 PM
