Do I need dual 2 ohm or dual 4ohm subs?
Old Aug 5, 2003 | 12:54 PM
96Z28/93TA's Avatar
Im going to buy 2 alpine 12" type R subs, Im going to use either the JBL 1200.1 amp or my MTX 302 2 channel amp. Should I buy the 2 or 4 ohm version of the alpines? Thanks
Old Aug 5, 2003 | 02:16 PM
Y2kPewterSS's Avatar
It depends on what final impedance you want to run. If your amp will handle a 2 ohm load it will be louder, if it won't you have to go with a total 4 ohm load. Two 2 ohm dual voice coils can be wired to get 2 ohms. The same 4 ohm speakers would be wired for 4 ohm.
Make sure you know how to wire them to get the correct load. Each 2 ohm speaker would have to be wired in parrallel then wired in series with the other speaker to get a total 2 ohm load.
Brian
Old Aug 5, 2003 | 03:57 PM
Ted J's Avatar
Re: Do I need dual 2 ohm or dual 4ohm subs?
If you go with the JBL 1200.1 you can run it down to either a 1 or 2 ohm load. Pretty nice actually.
With the MTX 302, I'm assuming it's only good down to 4 ohm bridged mono.
So, if you went with the JLB 1200.1 you could buy either the dual 2 ohm versions of the subs or the dual 4 ohm versions, the only difference will be in how you wire them up.
If you use the MTX 302 and it's only stable down to a 4 ohm mono load then you'd want to get the dual 4 ohm subs.
With that said, it seems like you have the MTX 302 already. Get the dual 4 ohm version of the subs and you can present the MTX 302 with a 4 ohm load if you wire it up correctly. If you plan on getting the JBL amp in the future then you can wire those 4 ohm subs on down to a 1 ohm load and the JBL 1200.1 would work on them.
Ted
PS - For details on how to wire them up just ask, I need to go and so something at work now otherwise I'd type it up for you.
Old Aug 5, 2003 | 07:56 PM
firebirdude's Avatar
Like Ted already said, get the dual 4 ohm version. If you decide on the MTX, wire the coils together in parallel and then wire the subs together in series. 4 ohm load. If you decide on the JBL, wire the coils in parallel and then wire the woofers in parallel. 1 ohm load.
Old Aug 6, 2003 | 02:09 PM
96Z28/93TA's Avatar
Thanks alot guys, I will ask for info on wiring them up as soon as my 12s get here. Thanks!
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
fift5
11
Oct 1, 2015 10:31 AM
plattted
9
Sep 20, 2015 11:23 AM
