DEI alarm install
Old Oct 27, 2003 | 05:20 PM
rs97's Avatar
need help on clifford alarm install
i am in the process of installing my matrix rs2 using bfrankers alarm install web page. i bought the alarm on ebay, and I cant figure out what the 5 included relays are for, one relay has wires connected to the alarm "brain", i think on all the other ones the wires that come out of the relay are just cut off.
Old Oct 28, 2003 | 08:04 PM
Javelin3o4's Avatar
the 5 relay system is for the remote start there should be a pink/pink w/ white wire, 2 reds, yellow, a ribbon cable that plugs into the alarm etc...
Red Wires (2) = 12v constant wire (heavy gauge)
Yellow = 12v switched wire
Pink = Ignition
Pink w/ White stripe = 2nd Ignition
Purple = Output to starter side of wire
remove the 2 30amp fuses until you are ready to test the system.
Old Oct 28, 2003 | 10:05 PM
rs97's Avatar
thanks! that helps a ton
Nov 18, 2023 07:21 PM
Heathen1
Jan 2, 2016 04:27 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Rich_z28
Sep 13, 2002 03:35 PM
