Deck resets..
Old May 18, 2003 | 09:31 PM
mrronatron's Avatar
Deck resets..
Everytime i turn off my car and turn it back on the deck resets...any answers?
Old May 19, 2003 | 05:34 AM
LS1 RULZ's Avatar
Sounds to me like you don't have it wired correctly. One of the power wires should stay hot even with the key in the OFF position.
Old May 19, 2003 | 10:21 AM
firebirdude's Avatar
Yep. That is 95% likely the answer. You are using an ign. wire where you should be using a batt. wire.
Old May 19, 2003 | 04:47 PM
slayer6x6's Avatar
if its wired correctly, hook a meter up to the constant wire and see if its reading anything. i had a car that after i shut the car off it would only send the constant wire 4V and thats not enough to keep memory. check the easy stuff first before you go searching for draws in the circuit.
alex5366
Jun 8, 2015 07:52 PM
Hobbyguy
May 26, 2015 02:15 PM
TitoPR221
May 26, 2015 12:20 AM
Spcquinn
Apr 10, 2015 04:02 PM
