Dash, Tail, Fog, and Interior Lights Not Working
Old Nov 9, 2012 | 04:17 PM
Misfit74's Avatar
1995 Pontiac Firebird Trans-Am.
Problem: Dash lights, tail lights, fog lights and stereo don't come on and neither do the dome and other interior lights.
Headlights raise up and light properly.
Fog, tail, and parking lights flash on when arming the alarm, as usual. I've had the alarm checked and ruled out.
Other notes: HVAC works, fans blow, but panel doesn't illuminate. Glove box light doesn't work. Interior lights on doors don't work.
Power windows and locks work fine.
Fuses at interior panel and engine compartment fuses and relays have been checked. None were blown/bad.
How do I fix this or what should I check?
Old Nov 9, 2012 | 05:44 PM
parkers Z28's Avatar
Re: Dash, Tail, Fog, and Interior Lights Not Working
any Corrosion on the fuse block under the hood? a few week ago some on else was having some of the same problems
he said that the BCM had a crack in it and that was( his problem ) you need to find out were the
power loss starts I think shoebox has the wire diagrams ??
Old Nov 9, 2012 | 07:06 PM
Misfit74's Avatar
I got help from someone on another board who pointed me to the fusible link(s). I tested them all and one didn't register. Repaired that and BINGO! Fixed.
Thanks for your responses.
Old Nov 9, 2012 | 07:29 PM
Thank you for posting what fixed your problem now when someone stumbles across this it will help them out and now I now another thing that will cause this problem
Jlo
Feb 3, 2015 09:41 PM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
