Courtesy Lights Acting Up?!
Old Mar 30, 2006 | 12:44 AM
khojo16's Avatar
Question Courtesy Lights Acting Up?!
ok well my car was this way when i bought it...the courtesy fuse is a 20A fuse and right now i have it unplugged because when i have the fuse in...the courtesy lights will stay on at all times, even when the car is turned off, doors closed, and let sit for well over a half hour...i removed the fuse bc i dont want them draining my battery...i do not have remote entry if that makes any difference...to me it sounds like a bad ground...lemme know wut u guys think and how to fix it please!!!
Old Mar 30, 2006 | 02:48 AM
Javelin3o4's Avatar
Re: Courtesy Lights Acting Up?!
might wanna check the door triggers, one of the switches might be bad.
Old Mar 30, 2006 | 06:17 AM
LS1 RULZ's Avatar
A 20A fuse for the courtesy light? That doesn't sound right to me at all. Are you sure thats the value thats supposed to be there? I seriously doubt that you have a bad ground. If it were the ground then the lights would work intermittently and not just stay on all the time. Have you checked to make sure your dash light dimmer isn't turned all the way up making the lights stay on? Either way I would check into the fuse size for that circuit. 20A sounds way too big to me.
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
reww86
Apr 27, 2015 05:17 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
97z28k&N
Jan 9, 2015 04:58 AM
Z284ever
35
Jun 26, 2002 12:20 AM
