Couple of HU questions
Old Dec 7, 2003 | 12:47 AM
mvnatedog's Avatar
Hi all-
First, I have the Bose AM/FM/CD that cam from the factory in my car still, and its been having problems lately. Aside from skipping every now and then (which I hear is common), the HU will occaisonally shut off entirely. The display goes off, the clock goes off, and nothing I do can make it turn back on (I've restarted the car, turned the radio on/off, etc.). It just turns back on by itself 10-30 seconds later. This doesn't seem to be related to road conditions, since its done it while the car was sitting still at a stoplight several times. I pulled the HU today, and didn't see any loose wires or any of that sort of thing. Anyone had this problem before?
My other question is really stupid, and I feel like an idiot for even having to ask. When I was reassembling the dash after replacing the HU, I could not get the trim panel that fits over the HU to fit on correctly. There's a clip-looking thing sticking down from the trim panel directly above it, just to the left of the fan speed ****, that I think is causing the trim panel to not sit down all the way. There's now a little gap between the stereo trim panel and the trim panel running under the HVAC controls, and when the dash lights are on at night, I can see light through the gap. What am I doing wrong here?
Sorry for the long post, thanks in advance!
Old Dec 12, 2003 | 05:58 PM
mvnatedog's Avatar
Anybody?
Old Dec 12, 2003 | 07:28 PM
LS1 RULZ's Avatar
The factory HU has proven time and again that it is NOT a reliable unit and it will continue to F-up as long as you have it. You can either get used to it or replace it all with a quality after-market setup.
Check to make sure that you have the HU seated back in the dash all the way.
Old Dec 30, 2003 | 06:29 PM
mvnatedog's Avatar
Thanks for the info, I finally got the dash fixed today. And it looks like I'll probably just buy a new HU and speakers sometime soon. Once again, thanks man!
P.S. Sorry for the late reply, I just today got around to looking at the dash again.
Old Dec 30, 2003 | 07:56 PM
Laymaster's Avatar
does it go off when you press on the brake or use any other type of accessory, or just at random? if it is just at random, i would assume the unit is a piece of crap.
Old Dec 31, 2003 | 02:46 AM
mvnatedog's Avatar
Yeah it's pretty much at random. I'm not too concerned about it anymore though, as like I said, I'll probably be getting a new unit sometime soon.
Old Jan 13, 2004 | 09:57 PM
pvkn1ght's Avatar
i have some very bad skipping on my bose HU...
suggestions please?
BinkZ28
Apr 20, 2015 09:10 PM
squarehead
Jan 15, 2015 07:02 PM
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
pete53
Dec 9, 2014 07:31 AM
