Convertible Sub Guys Stock or Not... Help!
I'm in the process of upgrading the crap stock setup (not Monsoon) in my T/A Vert. I need some good ideas for mounting a small sub in the truck preferably without tying up the trunk space.
Anyone use the small side area in the trunk on the driver's side with good results?
I'm sure I could squeeze a 6.5" in there but how to do the enclosure w/o using fiberglass. Did GM make a stock set up for the verts?
I don't need to thump... I just need some solid bass.
Thanks in advance!
Thanks in advance!
If you want to be able to hear and feel the bass when the top is down you will need a large system in the trunk. When I had my Camaro I had two Rockford Fosgate 12" being pushed by 900 watts RMS. I eventually moved it to the backseat.
a sub and amp in trunk
I have a 12 inch Alpine sub and amp mounted in my trunk and the only space I lose is the deep well where nothing really fits anyways.
Before I did it my golf clubs wouldn't fit correctly, not they fit fine. I will post pics later if you would like.
Mike
Mike
