Connecting 2 speakers to a 4way deck?
Old Jun 18, 2004 | 03:37 PM
firebirdjosh's Avatar
Can I just leave 2 unconnected or will that cook the amp? Its for a Kenwood deck I'm putting in an old MGB that only has 2 speakers.
Old Jun 18, 2004 | 04:48 PM
LS1 RULZ's Avatar
The amp will be fine. Just use the front or rear speaker outputs to power your 2 speakers and tape off the remaining wires so they can't short together or to ground.
Old Jun 19, 2004 | 09:42 AM
Thanks, I figuered that, but I play guitar and if you do that to a tube powered guitar amp you would have a dead amp. Just wanted to clarify, thanks alot.
Old Jun 19, 2004 | 09:45 AM
LS1 RULZ's Avatar
Nothing worse than the smell of your output tranny letting it's smoke out.
Old Jun 19, 2004 | 02:37 PM
Ex67's Avatar
if your use'n speaker level out-put's from the h/u to the speaker level in-put's on the amp.....use rear to rear for the best sound if you dont have a opiton to use rca's.....or you can buy a high level to low level converter which will allow you to use your speaker leed's from the h/u to the converter and rca's from the converter to the amp.....most of the converter's have a signal level adjustment to match the out-put volt's to the in-put volt's of the amp
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
