Chapman aftermarket alarm problems
Old May 24, 2008 | 03:02 PM
96blkform's Avatar
When I got my car around 5 years back the orginal owner I am guessing put in an aftermarket chapman alarm. It never really worked and in the time I have had the car whenever the battery is disconnected for the winter and then reconnected the alarm activates, the lights flah and the car will not start. I reconnected my battery after the winter today to fire it back up for the summer and the keyfob does not seem to be deactivating it (I have tried putting in a new battery in the keyfob. So the car will not start I tried to find a diagram of the wiring in the info I originally got with the car, but no luck. I was hoping someone could help me out with some info on how to pull this thing out. I do not need it and just want to have it out. Thoughts of office space run through my mind as to what I am going to do with it once it is out
Old May 25, 2008 | 09:01 AM
96blkform's Avatar
Here are some pics of the brain: Not sure where to go from here.
Old Jun 12, 2008 | 08:03 AM
THE_RUCKUS's Avatar
disconnect your battery.
trace the white and the white / red wire off the starter kill from the alarm to the starter in your car. i believe it is yellow, but i could be wrong. check your wires with a dmm.
reconnect the factory starter wire that both of these wires are connected to by using a butt connector or solder. This will bypass the starter kill on the alarm and allow the car to start normally (with or without the alarm armed)
Heathen1
Jan 2, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
mattstrike
Mar 11, 2015 07:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
dreamer1q
Jul 24, 2002 04:39 PM
