Changing HU
Old Dec 18, 2003 | 10:05 PM
GTO2Z28's Avatar
Changing HU
I read the faq, but still had a few questions. I have the adapter I used on my 93Z for the HU I will be using, what else do I need to install this HU into my 98 SS? I will be taking out the entire Monsoon system if that helps so I can hook up 2 amps, comps, sub, and changer. Is the Scoshe faceplate at SD okay too? It is over at sounddomain, I am going to order through them, and was going to just get it instead of the Metra. Thanks.
Old Dec 19, 2003 | 01:33 AM
Javelin3o4's Avatar
Is one of the amps going to be a 4ch. amp? I havent delt with monsoon systems F Bodys but if the wiring goes from the head unit to the factory amp then out to the speakers you will need to either run new wires from the 4ch. amp to all the speakers, or find which wires are for the speakers from the factory amp and connect those to the 4ch amp, cause if the wires just unplug from the factory amp you could just use those speaker wires, but it might be better just to run new wires.
Old Dec 19, 2003 | 02:11 AM
GTO2Z28's Avatar
I was wondering if I needed any adaptors for anything...
96SilverRam
Nov 20, 2016 11:19 AM
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
