car killing batteries??
Old May 5, 2006 | 06:39 PM
CHELOZ28's Avatar
My car has done this twice in the last 2 months, It first starts with the alarm making all these funky sounds, I try to turn it off(alarm) but nothing so I diconnect the alarm. After this the battery is completely dead, any suggestions on what to look for or where to start looking? BTW......this also has happened after my car accident and new door panels install, its still damaged on the front passenger side, but you can still drive it around....please help
Old May 6, 2006 | 12:34 PM
nervekiler's Avatar
Re: car killing batteries??
what alarm do you have? and it has remote start as well? when it starts does it grind the starter?
who installed it.
Old May 9, 2006 | 08:44 AM
NEEDAZ's Avatar
Put an ampmeter at the battery and post back how much current it is pulling with the car off.
Old May 12, 2006 | 06:08 PM
CHELOZ28's Avatar
No I dont have that kind of alarm, its a pretty old(about 4yrs old).
after the accident the battery was not damaged but the lights were.
Old May 15, 2006 | 12:16 PM
ucnu112's Avatar
+1
I had a very similar problem (car was killing the battery w/in 2 days if it wasn't driven). Using an ampmeter, I found the power antenna had a huge draw on it at all times. I pulled the fuse, and the draw stopped.
Old May 16, 2006 | 11:21 AM
CHELOZ28's Avatar
okay I will give it a try once I get home, its becoming a pain. My hood should get here next week and I want to drive it to the shop.
Old May 17, 2006 | 10:37 AM
CHELOZ28's Avatar
Okay I tried last night, but not sure how to read it. I set it on 10 and when I would test the battery in the car it would read half. We took off the battery and read again and it was full? So i also tested the battery it had drained before and that thing read a full.
Old May 17, 2006 | 06:09 PM
CHELOZ28's Avatar
Old May 19, 2006 | 04:48 PM
Rashiki's Avatar
What you need to do is go to your fuse panel, pull a fuse and insert the two prongs of the multimiter and read the current. When you start to see a lot of current draw, you may have a problem with that system.
liamcg97
Nov 25, 2019 05:55 PM
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
GC456
Aug 8, 2002 11:53 PM
