Camaro install pics
Old Jun 1, 2007 | 07:48 AM
  #16
megabass's Avatar
Originally Posted by RKPsk8er
puny sq 10's? I thought you guys were big supporters of elemental designs..?
When you compare two 12w7s or 12w6s or alpine type x or mtx9500 or any similar 12" high power subs hooked to a 1,000 watt amp and compare it to a setup with two sq10s at 200 watts each, there isn't much comparison. So that is where I'm coming from. If you go with a setup like that with expectations of 'similar' output to a well box and two powerful 12s, then you may be disappointed. You can point them any direction you like and you'll never hit 150 dbs. It's just not apples to apples. They are completely different setups and should not even be compared. Every well box that leaves our facility is capable of hitting 150dbs with the right equipment installed. I don't want anyone to think a truck box with two 200watt slim 10s can do that. It's just false.
Don't get me wrong, SQ10s work great in really tight spaces, like under truck seats where nothing else will fit. But they are somewhat limited. X-max isn't very much and they bottom out easily--especially over 200watts. It's all about your expectations. I would not use them wherever I can fit a regular sub like the k series.
Old Jun 1, 2007 | 01:55 PM
  #17
fredmr39's Avatar
The setup clearly wasn't designed for an SPL competition -- it was designed for a customer who obviously chose cosmetic appearance above all; and it looks like the customer got exactly what they wanted, which is all that matters.
I think whoever asked about the subthump enclosure was more concerned about the box placement...and not "will the SQ10s pound as hard as two 12s in a Subthump well box??"
Old Jun 1, 2007 | 03:45 PM
  #18
RKPsk8er's Avatar
yea thats me. i was just wondering if it sounded similar to a well enclosure assuming you were using the same sub/amp combo.
Old Jun 1, 2007 | 04:05 PM
  #19
megabass's Avatar
You would not want to use those in a well enclosure because the well box has way too much air space for them. Now if you had a pair of stealthboxes, then it would be very comparable in quality and output.
Old Jun 1, 2007 | 11:58 PM
  #20
RKPsk8er's Avatar
oh okay. well im more interested in the well enclosure. too bad they aren't cheap enough for my budget
Old Jun 6, 2007 | 02:57 PM
  #21
PentaVolvo's Avatar
putting a sub down in the well in a camaro in any eclosure will be louder then up on the rear shelf in my experience
Old Jun 6, 2007 | 06:34 PM
  #22
RKPsk8er's Avatar
I decided to make my own well enclosure. im almost done. I'll put up some pics of my install when im finished
Old Jun 6, 2007 | 06:43 PM
  #23
fredmr39's Avatar
Nice - can't wait to see it -- I made half of one...and probably would've been easier to make one more similar to subthumps since I could've gotten the volume I wanted easier -- I'm surprised more people don't make their own, though Subthumps cosmetic appeal is hard to beat (for me at least).
Old Jun 6, 2007 | 06:51 PM
  #24
RKPsk8er's Avatar
the only part of mine thats been difficult is making the angled cuts to fit the well snuggly (s/p?) Im covering mine in vinyl and I have a 1st gen camaro emblem that im going to throw on it. I'll get pis up when im done.
Old Jun 6, 2007 | 07:12 PM
  #25
fredmr39's Avatar
Yea I hear ya on the angles -- you must not have a table saw (I don't either) -- can't wait to see the pics!
Old Jun 6, 2007 | 07:28 PM
  #26
RKPsk8er's Avatar
well I do, but I used a skill saw for most of the cuts because something on the table saw wasn't working right. I have everything cut out now so its almost done. I just have to cut out the holes for subs and and wire terminals, and wrap it.
Old Jun 8, 2007 | 12:05 AM
  #27
PentaVolvo's Avatar
awesome cant wait to see it, honestly if you have like decent skills and take your time you can make just as nice of a box as are sold online for way less money
Old Jun 8, 2007 | 12:41 AM
  #28
RKPsk8er's Avatar
well I finished most of it today. I caulked most of it, cut out the speaker holes, and installed the wire terminals. I put in speakers and tested it out. there are a few air leaks on the piece that I had removed when I was caulking the first time. It sounded very nice despite the few air leaks.
Im going to caulk the rest of it tomorrow and wrap it in vinyl. I'll get pics up if I finish it before work.
Old Jun 8, 2007 | 12:58 AM
  #29
fredmr39's Avatar
progress pics are always nice too ya know... (start another thread tho, obviously)
Old Jun 8, 2007 | 01:47 AM
  #30
RKPsk8er's Avatar
well its a little late for progress pictures. At this point, all I could put up is wrapped, and pre-wrapped pictures. I'll def start a new thread when I do though.
