Bose Adapter
Old Apr 20, 2004 | 07:14 PM
  #16
MasterEvilAce's Avatar
It's probably close to the exact same as the GMAH12 one (which i have, for a THIRDGEN)
You adjust it with a small screw driver or so... Directions are included... it's basically like.. turn the volume up 2/3rds way on the radio, and increase the GAIN until the sound distorts, then turn it down a tad...
That's what it said to do, anyways.. I have a low powered aftermarket radio... I'm thinking about cranking the gains up all the way, since the max output of the radio is like 100watts, and max power per speaker is 45 watts.. so at most that would be 25 watts per speaker...
Old Apr 20, 2004 | 08:28 PM
  #17
pvkn1ght's Avatar
thanks
where did you get the interface? i've only found the PAC and Crutchfield adapters so far...
Old Apr 20, 2004 | 09:12 PM
  #18
mine is for a thirdgen (GMAH12) i THINK fourthgens are GMAH21....
not positive, but i believe that's correct
It's made by Peripheral Electronics, i ordered mine from Sounddomain.com
Old Apr 20, 2004 | 09:22 PM
  #19
pvkn1ght's Avatar
yea you're right, i found one here is this a different brand than Peripheral Electronics, or does PAC = Peripheral Electonics? heh
anyone know diff btwn PAC OEM-1 and PAC OEM-2 ?
Old Apr 20, 2004 | 09:54 PM
  #20
no, PAC seems different from PE..
Mine was a big green box, but it had adjustments like that box does...
I suppose they still do the EXACT same thing, internally, though.
I do not know the different between the PAC models, though
G-BODYT56
Jan 14, 2022 11:14 PM
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 22, 2015 02:31 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Bxlt1
Sep 10, 2015 08:16 AM
