Best Grounding Spot?
Old May 15, 2003 | 01:49 PM
snorkelface's Avatar
Question Best Grounding Spot?
Just like the title says. I need some suggetions. My amps are mounted in the pass rear fenderwell where the spare tire used to be. I tried the sandind the paint away, and gounding to the floor, but I still have a ton of noise. Thanks for all opinions!
Old May 15, 2003 | 02:50 PM
95 3.8's Avatar
I used the bolt on the seat belt.
Old May 15, 2003 | 02:52 PM
There's a bolt for the seat belts in the rear that I can use?
Old May 15, 2003 | 08:46 PM
ibanez6rg's Avatar
Yulp. I also used them in my old setup
Old May 16, 2003 | 10:25 AM
Are you talking about the bolt for the upperbelt mounting point for the rear seats for the belt tensioner? It has a large bolt faced upside-down, and then a large nut the goes down on top of it?
Old May 16, 2003 | 11:27 AM
95 3.8's Avatar
yes, thats the one, that way you dont have to drill new holes all over the way...
Old May 16, 2003 | 11:35 AM
Holy carp, that thing would need a huge ring terminal!
Where'd you pick pick up one that would fit over that bolt?
Old May 16, 2003 | 12:12 PM
95 3.8's Avatar
I used the one that came with the wiring kit, just loosen up the nut, slide it in (like a spade) and tighten up the nut, this was my experience, you should try what ever you find more suitable for your needs.
Old May 16, 2003 | 12:14 PM
StreetZ's Avatar
Power tools work wonders....try drilling out your ring terminal
Old May 16, 2003 | 12:15 PM
I tried that before, but I don't have a d*mn vise to hold the terminal down with.
Old May 16, 2003 | 01:50 PM
95 3.8's Avatar
well, it worked fine for me
Old May 16, 2003 | 01:58 PM
Did you use a vise, or something elso to hold the terminal down. Everytime I try, the terminal just gets stuck on the bit and spins with it.
Maybe I just need to go to the gym more.
fift5
11
Oct 1, 2015 10:31 AM
autoxr166
Sep 25, 2015 04:21 PM
95craz28
11
Sep 12, 2015 07:47 AM
ChrisFrez
Sep 9, 2015 06:52 AM
92_RS_305
Sep 8, 2015 07:47 PM
