Best bang for the buck 5ch amp?
Old Mar 19, 2007 | 03:49 PM
Red97LT1's Avatar
Got some CDT speakers for my doors and my sail panels and a sub coming within the next couple days. I plan on using a 5 channel amp to power them all. Any suggestions?
Old Mar 19, 2007 | 09:38 PM
fredmr39's Avatar
specs on everything, well the sub specifically, would help (also what is in the sails)
Old Mar 19, 2007 | 10:59 PM
PentaVolvo's Avatar
Phoenix gold has a nice cheap 5 channel
Old Mar 20, 2007 | 01:18 PM
valter's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220093989207
MTX Thunder 4405 is a cheaper alternative
Old Mar 20, 2007 | 06:04 PM
Red97LT1's Avatar
The CDT for the doors have a 80Watt rms and the sails have a 90watt rms.The sub is a MTX(got cheap from a buddy)that has a 225 watt rms. That Mtx amp looks a little under powered. I have been looking at the Hifonics Zeus ZXi8006 and the Soundstream XTA600.5 that I can get for around 180.00. Then agaian,if I change out the door speakers and get a sub,do I really need the sail panels? I mean as of now they are ok,but would replacing them be a difference?
Old Mar 20, 2007 | 11:03 PM
Critter's Avatar
http://cgi.ebay.com/ebaymotors/MTX-B...spagenameZWDVW
2 of those maybe? u have to remember that the older amps were rated at countinous power and the new ones at peak, this make a big difference. you can't go wrong with the old blue thunder series amps or ppi!
Old Mar 20, 2007 | 11:39 PM
Compstall's Avatar
I have been using a 5-channel Hifonics amp for the last 3 years w/ good luck. It's powering four 6.5" Infinity's along w/ a 10" JL Audio sub no problem.
This is the one I own:
http://www.onlinecarstereo.com/CarAu...roductID=13118
Old Mar 20, 2007 | 11:43 PM
bt96ss's Avatar
Look into a Kicker 5 channel. The sub output is over 400 easy. The other four channels are over 50 watts cea rated each.
Critter I can't believe you would recommend that junk to ther people seeing all the problems you have had with yours.
Old Mar 21, 2007 | 03:56 AM
fredmr39's Avatar
Cheaper? http://www.sonicelectronix.com/item_1613.html
new 5ch http://www.edesignaudio.com/edv2/pro...roducts_id=550
Old Mar 21, 2007 | 12:44 PM
Critter's Avatar
junk? i bought the 3200s blown on ebay for 60 each and sent them to mtx for repair costing 90 More totaling 150 for 750 bridged. how much would that power cost new... i put a screw though a wire blowing the only 1amp.
Old Mar 21, 2007 | 12:48 PM
Critter's Avatar
That one is the only one that has broken and is the one i have taken to you. so because i put a screw through it the amp is junk...
Old Mar 21, 2007 | 02:14 PM
valter's Avatar
MTX 4405 normally goes under $100 on ebay. And I wouldn't touch anything from modern PG at all... Outsourcing at it's finest. I would be surprised if you can get old PG Titanium 5-ch for less then $600-$800, those was hand-made, over engineered, used BJTs outputs, sound is amazing. Can't say anything about ED amp, but would be more then happy to evaluate it.
Old Mar 21, 2007 | 03:42 PM
fredmr39's Avatar
Sorry didn't even read what you wrote besides the word cheaper, thought you were referencing the amp linked.
http://cgi.ebay.com/ebaymotors/MTX-T...spagenameZWDVW
Old Mar 21, 2007 | 08:22 PM
Red97LT1's Avatar
All this stuff is giving me a headache. I replaced the factory monsoon speaker in the sail panels with another 6.5 midbass and I could tell that the factory ones put out alot more bass.Yes,they were 4ohm and running off the monsoon amp.Just wanted to see how they would sound. I have been debating as to whether or not I want to just keep the Monsoon midbass speakers since they are ok,and just replacing the front door speakers and running them off my Eclipse hu and then get a sub with a mono amp and be done with it.Then again,I may just keep it all and get a sub.
Old Mar 21, 2007 | 09:54 PM
fredmr39's Avatar
ur call man....check out the DVC 4 ohm eu700s for the rear sails
