Audiobahn or jl amp help me choose!!!!
i have mb quart rce116 up front and pioneer revs in the back. im getting either jl audio e6450 6 channelamp with 1 channel to each speaker (45 rms watt)and bridge the last 2 for sub and run a 10 inch w3v2 or should i get
audiobahn a66001t
4 Ohms Stereo: 75 x 6 RMS 150 X 6 PEAK
2 Ohms Stereo: 105 x 6 RMS 210 X 6 PEAK
4 Ohms Mono: 210 x 3 RMS 410 X 3 PEAK
2 Ohms Mono:
and run their 10 inch AUDIOBAHN ALUM10Q but it says 3 or 12 ohm operation? can i make that work? if not what audiobahn subs are good in a sealed camaro spare tire box?
JL AUDIO SETUP OR AUDIOBAHN. both will cost about the same please help me. and i dont care about looks actually i think audiobahn is goddy but i iwll cover it anyways. thnaks guys plese help
audiobahn a66001t
2 Ohms Mono:
Re: Audiobahn or jl amp help me choose!!!!
I'd go with JL all the way if I could.
I have an Audiobahn amp driving a 10" JL W0,
and it rocks, but I hear that a lot of people have
problems with audiobahn amps, but never a bad word
about JL.
www.fbodyaudio.com
about JL.
www.fbodyaudio.com
Well whatever you do, dont use the same amp for subs and highs. I would stick with 2 separate Audiobahn amps. Highs and subs on the same amp is just asking for trouble with so many things I'm not going to both listing it all.
If those are the only choices I say go JL. Though not my favorite JL is far superior to anything Audiobahn has to offer. If bling is your thing go Audiobahn but for reliability and performance go JL. THere are too many other fine products out there to just limit yourself to those two brands. I have hooked up a ton of both companies equipment and I know all the problems Audiobahn and JL has first hand. Audiobahn amps are ok but are little overrated in their power ratings. There woofers are nothing special at all. The only real problems JL has is that people try to push W0 woofer like they are W7s. There is nothing wrong with using the same amp for subs and highs. Assuming its a four of five channel.
RUENUF
Mar 13, 2016 03:37 PM
Brian Demeter
Aug 17, 2002 08:07 PM
