Anyone made a board for rear sub in hatch?
Old 08-07-2002, 11:22 PM
regular Joe's Avatar
Question Anyone made a board for rear sub in hatch?
I have a 10" Rockford Fosgate Punch DVC sub I am going to install along with a MTX thunder 8200 amp bridged 2 ohm mono. Thundered hard, clean, and loud in my 01 Frontier with small sealed box. But that was traded for my Bird.
Was planning on using MDF board all way across lower part of hatch and using 3/4 thick foam weatherstrip around edge of T-top storage/ trunk to help seal in some. As I mentioned I have T-tops so I need to be able to put them away in car when removed so that is reason for using board.
Thanx
Joe
White 97 Firebird Formula
I like Mustangs.
They are delicious!
I just plain HATE rice cars.
regular Joe is offline
Old 08-08-2002, 05:59 AM
LS1 RULZ's Avatar
Post
...along with a MTX thunder 8200 amp bridged 2 ohm mono.
8200? Do you mean 81000D? If so then you cannot bridge the amp. It is a single channel amplifier, not stereo.
Why bother with a board that you'll have to remove to store your tops? Get a Stealthbox instead.
LS1 RULZ is offline
Old 08-08-2002, 07:53 AM
Lynxis's Avatar
Post
sounds like a lazy idea.... no offense.
if its a ten, then i would get the stealth box, or make one yourself to fit in the cubby hole on the drivers side of the well
shouldnt be too hard... the plastic panel will flex and should conceal f ups in fitment pretty well
1994 Camaro Z28 Patriot Red
Mods: MSD Wires, K&N Filter, LOUDMOUTH, AVS TailCovers, CAMARO insert
Stereo:
HU: Clarion DRX7675z
Signal: Audio Control 2XS
Full Range: Infinity Kappa Components, Audio Art Amps
Subs: 2 Rockford Fosgate Power DVC 12's, U.S. Amps US 400 (old school rev. 4)
Power Wires: Scosche
Signal Wires: KnuKonceptz
E.T: 14.09 @ 94.73
Let off @ 1100'
Lynxis is offline
10-31-2016 11:09 AM
dale3in98
02-14-2015 12:18 PM
01-13-2015 09:52 PM
Joes96z
12-13-2014 07:48 PM
siguy
11-27-2014 10:07 AM
Quick Reply: Anyone made a board for rear sub in hatch?
