Amp suggestions?
Old Sep 29, 2002 | 08:03 PM
Naegash's Avatar
Amp suggestions?
Which amp would you guys suggest to power two 12 inch Kicker Comp VR's. I want adequate power so I know the subs are there, but I'm not trying to break windows or anything like that. Thanks for helping out an audio newbie
Old Sep 29, 2002 | 11:38 PM
x7x7's Avatar
what impedance?
Old Sep 29, 2002 | 11:49 PM
Naegash's Avatar
2 ohms ( I think thats what I want to run, still not too familiar with what different impdences do for me)
Old Sep 30, 2002 | 12:06 AM
x7x7's Avatar
no, no......what's the impedance of the subs?
Old Sep 30, 2002 | 12:26 AM
Naegash's Avatar
I don't know, I haven't purchased them yet, this is all so I know what to buy in the future. Sorry that im not much help with this
Old Sep 30, 2002 | 12:58 AM
x7x7's Avatar
The Comp VRs are rated at 400W RMS each. So you'll want at least 300W RMS to each. I would go with a JBL 600.1. For that amp you'll want to go with the dual 2 ohm version of the Comp VRs. That way you can run each sub's voice coils in parallel for a 1 ohm load each, then wire them together in series for a final 2 ohm load. That amp will put out about 350W RMS to each sub. Drop those subs in 1-1.25 cubic feet sealed each and you should be good to go.
BTW, for this setup I recommend that you go with 75-100W RMS per side for your component set.
Old Sep 30, 2002 | 03:36 AM
Naegash's Avatar
Now should I get 4 component speakers or just 2 for the front (or rear I dont know where they sound the best) and get 2 other speakers?
Old Sep 30, 2002 | 09:02 AM
firebirdude's Avatar
Get a set of componenets for the front. And I personally would get just a set of co-axils for the rear. A lot of people prefer no rear speakers at all... but I personally like a little rear fill.
Old Sep 30, 2002 | 11:38 AM
x7x7's Avatar
It's up to you but if you're not sure I would just get the front speakers first then if you decide later that you want rears too, get some decent coaxial speakers and just run them off the HU. You're not going to want ear piercing rear fill and I'm sure your passengers in the rear won't either.
Old Sep 30, 2002 | 11:57 AM
Naegash's Avatar
Which amp do you suggest for running the front component speakers?
Nayr
Mar 3, 2023 08:34 PM
Double aught
Oct 2, 2015 11:29 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
z28cam1993
Sep 9, 2015 04:08 AM
