Amp shutting off..
Old Oct 31, 2007 | 07:31 AM
Iroczdaroad91's Avatar
Amp shutting off..
I need help on something...the other day i was putting some subs in my friends camaro and we got everything done..except only the radio plays...when you switch over to play a cd the amp shuts off and only the car speakers play. Can any one help me with the problem...its frustrating..thanks
Old Oct 31, 2007 | 09:19 AM
valter's Avatar
Check, that you have +12v on remote turn-on wire on your amp while headunit in CD mode.
Old Oct 31, 2007 | 01:15 PM
_94Lt1_'s Avatar
Its on until you start to play a cd. Then does it shut-off or does a red light come on?
Old Oct 31, 2007 | 03:59 PM
RKPsk8er's Avatar
sounds like a headunit problem. your remote wire is working properly when the radio is playing the radio. It sounds like your remote wire isn't getting power once the cd player changes to cd mode. Get a multimeter and test your remote wire for power in cd mode.
Does your head unit have an option to toggle your remote power? if not you might need to replace it.
Old Nov 1, 2007 | 07:49 AM
when you push source to go to the cd player the amp completely shuts off...ill check the head unit ..thanks though i appreciate it...it just gets frustrating...
Old Nov 8, 2007 | 10:46 AM
Chevyssoccer's Avatar
some head units have both a Power antenna wire(blue) and ampturn(blue/white) if you are on P.A. when you switch to cd it powers down. If it only has a P.A. wire then you can A) change the radio setting to stay on regardless of source, if possible or B) find an accesory power wire (red wire)
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
KYWes
Sep 26, 2015 08:49 AM
Greg88
Sep 20, 2015 07:14 PM
