Amp question?
Old Apr 3, 2007 | 05:45 PM
Red97LT1's Avatar
Amp question?
If an amp is rated at 2ohms,then I can take two subs and wire them to show the amp a 2ohm load.Correct??
Old Apr 3, 2007 | 06:30 PM
fredmr39's Avatar
yea -- here are possible ways to achieve a 2 ohm load using two subs:
WITH SVC SUBS ((1 voice coil per sub):
-wire two 4ohm single voice coil subs in parallel
WITH DVC SUBS (2 voice coils per sub)
-if you have two subs with impedances of 2 ohms per voice coil, then wire the voice coils on one sub in series with each other and wire the subs themselves in parallel with each other
-if you have two subs with impedances of 2 ohms per voice coil, then wire the voice coils on one sub in parallel with each other and wire the subs themselves in series with each other
Old Apr 3, 2007 | 07:34 PM
Red97LT1's Avatar
Thanks Fred. The reason I ask is that a buddy of mine is selling his audio equipment(money issues)and he has an ALPINE MRP-M450 that he said he would sell me for $100.00. Since he needs the money,I was going to grab it. The specs look good,so I was going to either get a dual 4ohm/2ohm sub for a stealth box or get two 4ohms for a dual setup box.400rms x1 @2ohm seems pretty good to me.Just need to figure out what sub(s)I want to get. Alpine,Kicker,Been looking at the ED subs,etc.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
silvermansteve
Mar 4, 2015 05:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
