Which amp for Focals????
Old Sep 17, 2004 | 01:52 PM
texasTA's Avatar
I have a set of Focal polyglass 165v components that I am about to put in my Trans Am. What would be the ideal amp to power just these components? I have a seperate amp to power my sub.
Old Sep 17, 2004 | 04:33 PM
LS1 RULZ's Avatar
Re: Which amp for Focals????
Give us a list of amps to choose from. What kind of budget do you have to work with? What's available to you in your area? How much power are you sending to your sub? Your rather vague question is hard to answer without a little more info to work with.
Old Sep 17, 2004 | 06:23 PM
texasTA's Avatar
I just don't know what type to run. I am going to run a Type R 10 in a stealthbox with an Alpine MRV-T320 powering it. I just need to know which amp to use on the front components. They say that the ideal watts to it is 75w, so does that mean I need a 150 watt amp???
oh, and all stores are around me.
Old Sep 17, 2004 | 06:52 PM
LS1 RULZ's Avatar
A quality amp that can deliver anywhere from 50Wx2 to 75Wx2 should do the trick nicely. Another Alpine amp would be good if you want it to look like the amp you already have. If that kind of thing is important to you.
Old Sep 21, 2004 | 08:50 AM
bt96ss's Avatar
For Focal I would get an amp that puts out at least 100 watts rms. I have found that most high end highs don't live up to their potential with less than their rated power. My Diamond hex's are rated at 150watts rms and I found that anything less than 100 watts on each sounded horrible no matter what brand amp it was. Overpowering sounded far better than underpowering. Had way more headroom and not to mention midbass was faa better.
Old Sep 22, 2004 | 06:42 AM
justa25thTA's Avatar
So you are saying that your Focals don't sound decent unless they are at max volume? Just because your amp CAN put out 100 watts per channel doesn't mean that they are ALWAYS putting out that much power.
Old Sep 22, 2004 | 08:56 AM
bt96ss's Avatar
NOt saying max volume. Just saying with an amp that has the potential to overpower the speakers you can give cleaner sound and more headroom before the destortion from turning up the radio kicks in. With a 50-75 wattrms amp I had no midbass and the tweeters were loud. By setting the tweeter to minus three and giving the component set more power the midbass has a chance to shine and really sound good. I hope I explained this right. All I know is everytime I build a system now I tend to go for an amp that is slightly more powerthan the speakers are rated for and tune it in such a way that the highs sound great.
Old Sep 22, 2004 | 02:24 PM
JB'z 94's Avatar
When purchasing amps, I personally like to get one with a little headroom. I have 165w, and I try to run 125 watts to each channel(the longest I have ran the same setup was around 4 months lol). Remember, you can always turn a gain down with an amp with a little too much power, but turning a gain up with an amp with too little power can clip your signal.
Old Sep 22, 2004 | 05:14 PM
bt96ss's Avatar
Thats the point I was going for. THanks
Old Sep 22, 2004 | 11:52 PM
fireman's Avatar
I ran a PPI 40wx4 to a set of Polykevlar 130ks and a set of Polk 6x9s and it sounded awesome. I was able to crank those Focals till my head hurt and they sounded awesome with only 40w to each set.
Old Sep 23, 2004 | 08:25 AM
bt96ss's Avatar
you should have tried bridgeing the amp to two channels just on the focals. you would have really creamed then.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
Brian Demeter
Aug 21, 2002 02:07 PM
PaulN64
Aug 8, 2002 05:39 AM
