Amp for Door & Panel speakers
Old Dec 26, 2006 | 07:19 PM
slipping's Avatar
I want to get an amp to run my door and sail panel speakers. They are pioneer, i believe the rear are 6.5" 90w and the door are 5" not sure watt. 1st question is what size should i get. 2nd question is I have not wired an amp to these speakers before so how should i do it, unplug wires from hu to speakers and run wires from speakers to amp?
Old Jan 2, 2007 | 09:53 AM
fredmr39's Avatar
Are all the speakers aftermarket 4 Ohm? The door is.....5"? Is that part of a component setup or something? RMS ratings are useful in determining how much power you want your amp to have... Your best (and easiest) option is a 4ch amp thats stable @4 Ohms with the power you want.....you could also get a 2 ch amp though as long as it's stable @ 2 Ohms and you wire the 4 Ohm speakers in parallel (likely cheaper..but some drawbacks). All of this is assuming you have 4 Ohm aftermarket speakers only.
2QUIK6
Sep 17, 2016 02:31 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Sep 18, 2015 04:01 PM
Wart Hog
Sep 8, 2015 05:53 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
