Alternative 12V Ignition wire
Old May 19, 2003 | 01:48 PM
Mitch2067's Avatar
Question Alternative 12V Ignition wire
Ran into some electrical problems with m camaro, so I can no long use my 12V Ignition wire on the wire harness for installing my aftermarket radio, becuase if i do the radio will be on all the time....
looking for a different wire that would work. I did wiring it into the power accessory wire, but that didn't work either...
help would be appreciated.
Old May 19, 2003 | 04:29 PM
slayer6x6's Avatar
are you sure its not just a blown fuse?? if its not than you can tap off a wire for the heater controls, i do it all the time at work
Old May 19, 2003 | 07:54 PM
Mitch2067's Avatar
I'm sure its not a blown fuse...
one of my modules isn't working so in order to use my radio or power windows, I have to bypass power from the 30 amp defog/seats fuse to the 30 amp windows fuses, so my power windows and radio works...
the only problem with this is I now have constant power to the windows and radio... meaning I can use my radio and windows when the car is off and my radio no longer turns on and off when i turn my car on and off...
so isn't of trying to replace a module, which i have no idea where its located in my car i'm going to just trying and use a different 12v ignition wire...
Old May 19, 2003 | 09:08 PM
slayer6x6's Avatar
sounds like your hacking up all your wiring
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jul 4, 2005 05:00 PM
