Aftermarket Head Unit Issue
Old May 10, 2004 | 07:40 PM
96ChameleonZ28's Avatar
Installing a JVC head unit in my 96 Camaro. It has the bose installed factory sound system, and it seems that now I get no sound with everything hooked up through the OEM harness plug that I bought....I'm sure that there is an easy fix to this and it probably has to do with the bose system. Please help me out!
Old May 11, 2004 | 01:26 AM
Lower's Avatar
If you're running through the factor speaker wires, you're probably not powering up the factory amp.
It's been a year since I looked at mine, but I know I had to patch into the amp turn-on wire in dash with the head units antenna turn on -this means the antenna turn on will actually have two connections -one to the antenna as it should be in the harness, and you'll have to connect the amp turn-on as well at some point.
I don't recall which color the amp turn-on even is, but if I remember correctly, it'll be obvious because there will be a wire on the dash side, but not one coming off the harness on the head unit side.
Maybe someone that has already conquered this trouble on a 96 can chime in with more details.
Rod Bender
Jan 1, 2015 03:18 PM
u8dusst
Sep 6, 2002 09:25 AM
TireSmoke
Aug 6, 2002 10:25 PM
Snake Slayer
Jul 29, 2002 12:39 PM
95 Mystic TA
Jul 29, 2002 08:50 AM
